![]() | Home > Maintenance & Mods (L322) > L322 td6 radiator removal help please. |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
From RAVE it looks like it's the same as the V8. Since you're in Hertfordshire, don't waste your money buying a fan tool. PM me, come over at the weekend with your new coolant and we can get it changed.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
this is from our wiki and although its for the v8 it should give you an idea,
I found it easier with two spanners, one to hold the pulley the other to undo the fan nut. The Halfords ones are "not quite" long enough either. (the good whack method does also work, though)
Show n shine Member Since: 01 Jun 2016 Location: Hertfordshire Posts: 55 ![]() ![]() ![]() |
So the aircon fan also works as rad fan ? Is this correct ? |
Just to add - I found it necessary to remove the undertray to disconnect the gearbox rad. I guess the TDs don't have one? |
I have the under tray off as I steam cleaned all the underside. I will be underbody sealing and waxoyling. Just because I love to tart her up. |
Sorry forgot to remove undertray (have added now)
Right. Productive day guys. Changed the rad without taking out the fan and cowling. Replaced with with an oe part behr. Done a flush with water a few times to totally get rid of old coolant. Tomorrow I will add need coolant with the correct mix. I also got to work with the rust on chassis with krust and will be underbody sealing and waxoyling. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Can you give a step by step guide how to remove the rad with the cowl and fan in situe 2007 TDV8 VSE
I made sure to that the coolant clips undone before I emptied the coolant.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
S n s . Well done. |
Thanks for the how to. |
