Home > Maintenance & Mods (L322) > High Performance Brake Upgrade |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
thats three then.... ... - .- -. Y. O. L. O. . |
24th Nov 2010 11:21am |
You'll get better braking and more change from JE in Coventry. Very similar calipers but none of the silly ceramic stuff.
24th Nov 2010 12:47pm |
The Brembo's on the TDV8 are more than sufficient. Go to a local paint shop and ask them for a quote to professionally clean and then paint the callipers using heat resistant Red paint.
24th Nov 2010 1:26pm |
joanne Member Since: 19 Nov 2010 Location: uk Posts: 427 |
Thanks I think i have decided not to go with the 6.5k upgrade but to go with buying the new brembo calipers and have them fitted after xmas!.
24th Nov 2010 1:54pm |
specman Member Since: 20 May 2010 Location: Fife Posts: 250 |
I have got some spare change down the back of the sofa if you want to start talking about your TDV8 coming to Fife. Might even throw in some new red Dior sunnies to match your shoes, now there's an offer you simply cannot refuse! |
24th Nov 2010 2:33pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 |
Also, don't know if it's definitely true or of any use but I understood that opening a door prior to jacking will stop the suspension playing silly beggars.
24th Nov 2010 2:59pm |
I've heard this but I never have any problems keeping the doors closed and jacking up the vehicle |
24th Nov 2010 3:03pm |
and putting it into high mode helps.... ... - .- -.
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
The actual configuration is in the handbook. Low range needs to be selected. DO NOT jack it with the keys in or near the ignition, it WILL try and self level! Land Rover Addict
24th Nov 2010 4:21pm |
