Home > Maintenance & Mods (L322) > High Performance Brake Upgrade
Fox wrote:
Ebay is your friend. Thumbs Up
thats three then.... Cool ... - .- -.
Post #38850 24th Nov 2010 11:21am
joanne
Thank you Fox. !!!
I think I may try to do this myself...... If i get more than a week in the uk I can see the steam cleaner coming out !!!
Post #38854 24th Nov 2010 11:25am
mzplcg
You'll get better braking and more change from JE in Coventry. Very similar calipers but none of the silly ceramic stuff.
Depends if you're doing it for cosmetic reasons or performance reasons really. If it's cosmetic then have your calipers done by these blokes. LINKY
They might even do custom colours to match nail polish / handbags / lippy etc Whistle Whistle
Post #38935 24th Nov 2010 12:47pm
The Brembo's on the TDV8 are more than sufficient. Go to a local paint shop and ask them for a quote to professionally clean and then paint the callipers using heat resistant Red paint.
Total Cost about £250 probably and they will look and perform great. Thumbs Up
Post #38963 24th Nov 2010 1:26pm
joanne
Thanks I think i have decided not to go with the 6.5k upgrade but to go with buying the new brembo calipers and have them fitted after xmas!.
I am also test driving the new 4.4 TDV8 autobiog on saturday so may be looking to do a trade in deal
MZplcg: I have Red handbag and red shoes. Hence the need for red brembos !
Post #38967 24th Nov 2010 1:54pm
specman
Scotland 2016 Range Rover Vogue SE SDV8 Aruba
I have got some spare change down the back of the sofa if you want to start talking about your TDV8 coming to Fife. Might even throw in some new red Dior sunnies to match your shoes, now there's an offer you simply cannot refuse!
Post #38990 24th Nov 2010 2:33pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Also, don't know if it's definitely true or of any use but I understood that opening a door prior to jacking will stop the suspension playing silly beggars.
HTH.
Post #39019 24th Nov 2010 2:59pm
HTH.
I've heard this but I never have any problems keeping the doors closed and jacking up the vehicle
Post #39023 24th Nov 2010 3:03pm
and putting it into high mode helps.... ... - .- -.
Post #39024 24th Nov 2010 3:03pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
The actual configuration is in the handbook. Low range needs to be selected. DO NOT jack it with the keys in or near the ignition, it WILL try and self level! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #39055 24th Nov 2010 4:21pm
