Home > Maintenance & Mods (L322) > Bluetooth Car Battery Monitor
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Crikey if your really paranoid about your battery this has to be for you;
http://www.ebay.co.uk/itm/JMP-Battery-moni...Sw4HVWD5yt Many thanks
Paul
Post #389543 31st May 2016 5:52pm
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
I have the Accutire MS-51GB ones on a few boats cars and bikes good kit for pennys 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #389546 31st May 2016 6:07pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Brilliant! THIS WRECKAGE
Post #389621 1st Jun 2016 8:25am
wealy
Have you got this fitted? Does it work well?
Post #389627 1st Jun 2016 9:04am
I'd be worried about it draining the battery Whistle 2008 MY Supercharged
Post #389628 1st Jun 2016 9:08am
Laughing so true.... ... - .- -.
Post #389629 1st Jun 2016 9:11am
Can't see the point myself, it lets you know within 6 meters of the car whether the battery is flat or not, walk a few paces and try to start it and you will get your answer...
Now, if it sent you a text when the battery voltage got below a certain level it would be helpful..... Thumbs Up Pete
Post #389639 1st Jun 2016 10:20am
Pvw10
Knowing our luck Pete it would fail to send a text as the battery was to low Rolling with laughter Many thanks
Paul
Post #389698 1st Jun 2016 4:14pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Here's a version which *can* send you a message when the battery drops below a certain voltage, looks very handy - I've just ordered one Smile
https://www.aliexpress.com/item/33056891147.html
(Or para mi amigo's espanol: https://es.aliexpress.com/item/33056891147.html)
Post #573657 21st Nov 2020 4:01pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Dont expect too much with the range, 100 metres at best, sturround it with meatl and you may get 10 metres or thereabouts. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #573672 21st Nov 2020 5:40pm
Siftah
Yeah, definitely not expecting much range but the car is parked less than 10 metres from where I sleep Smile
I'm intending on getting the drain issue nailed quickly, so I don't have to worry about it, but it'll be a nice little backup - the voltage readings taken from ODBC (or via the GAP tool) or via the cigarette lighter sockets always seem to read low compared to sticking a DMM across the battery, so hopefully this will be more accurate.
I've found I get readings of 12.4 to 12.5 consistently from the cigarette lighters, so I figure they're regulated voltage. Similar sort of readings from the GAP tool, consistently a few volts off from a direct reading from the battery.
When the engines running, oddly, the GAP tool reads 14.6v or so, as you'd expect. Very odd.
Post #573679 21st Nov 2020 6:19pm
Siftah
Range isn't much of an issue with this device - it stores the data internally for 24 hours or more, so when you return within range it syncs it down to the app. Works great!
Post #582151 2nd Feb 2021 7:00pm
