Home > Technical (L322) > 'Hunting/juddering' on L322 02 Diesel |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
It doesn't matter how much magical mouse milk you throw at the injectors, it will not repair a worn out tip / nozzle or fix a broken valve. And if it was so good at getting the injectors cleaned then there would be no place for specialists with ultrasonic cleaning equipment and test rigs. If they were purely mechanical injectors, then you could test them outside of the engine and determine if they needed a new tip, but as the all the range rover diesels from 2002 on are all common rail injection, they are electrical, so with out the test rig there is no way of testing them properly. Having gone to all through all the motions of removing the injector to "test it" you might as well just take it to Bosch and get a warranty and piece of mind.
2nd Oct 2015 11:18pm |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 |
Thank you Miggit and others. I am sorry about the late reply to your posts but holidays and working away have meant that the car hasn't had too many trips to do.
15th Nov 2015 6:31am |
Your Trans fail safe is not the engine but if it has sat for a while it's more that likely a low charge in the battery, if you've had a flat battery going from full lock to full lock and back to full lock with the steering might cure it, sorry I can never remember which way to turn it first, hence the back and forth Yesterday I couldn't spell Engineer... Today I are one!
15th Nov 2015 9:23am |
Thank you for your swift update.
15th Nov 2015 9:55am |
Thanks Craig.
15th Nov 2015 10:06am |
^^ I was getting at that, if the battery is not fully charged then all sorts of silly bongs go off. As I said if it has sat around for some time then it could be a low charge issue, but a run to Kettering should sort that out
15th Nov 2015 10:14am |
<> 'Knowledge Is Power' |
17th Nov 2015 5:51am |
Thanks Miggit.
That will more than likely be a rotten loom on the rear, the PDC has a bit of a reputation for bad connections, especially on the back , it could be a sensor, but the fact that it came back from the dead makes me think it's the loom. On the upside you can get a new one for around £40
17th Nov 2015 11:15am |
Yep !! The battery charger will be on the car before night time descends !
17th Nov 2015 3:02pm |
Hello everyone who tried to help me regarding the 'juddering and hunting' performance of my L322.
31st May 2016 6:17pm |
