Home > Maintenance & Mods (L322) > L322 would not start and engine failsafe prog message |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
The problem will almost certainly be power related rather than EAS related... Start with looking at battery cables and engine earths. Sounds like there maybe a fault with a connection.
29th May 2016 1:23pm |
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 |
Hi, thanks. I have recently fitted a replacement dvd drive for the sat navigation, I wonder if it could be that? Only other things have done is to replace front side lights with led bulb and replaced rear window wiper and unblock. |
29th May 2016 1:32pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8232 |
As Craig said, classic dirty contact on one of the large leads from battery via positive post on bulkhead to started and alternator...
29th May 2016 2:28pm |
So you think I should disconnect the battery and clean the battery lead contact surfaces?
29th May 2016 2:53pm |
AFAIK on our earlier ones it doesn't wake up when the key gets near, only when you unlock it...
29th May 2016 3:18pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
when you look at the clamps on the terminals, there should be a bit of the post sticking above the clamp. this means the clamp is (low down) and gripping, if its high on the tapered post, it will be clamped, but possibly not gripping. its normal to clean up the posts, and inside the clamps, with some sandpaper type stuff, and then to wipe some decent amount of Vasalene over the contact areas and then bolt down etc. this stops the build up of that white crust, that makes the connection 'dry'/high resistance.
29th May 2016 10:39pm |
Problem solved. Loose negative connection in battery, didn't appear lose after I first looked at it, I guess the mechanic must have disconnected it when I had the lpg system serviced. |
30th May 2016 7:07pm |
