Home > Technical (L322) > How to enable passenger airbag....?
If I could I'd make it set off every air bag with the smallest collision... If it gets hit, I don't want it back....... Pete
Post #389051 28th May 2016 9:03am
After all the laning would you notice the difference Wink
And with metal bumpers like mine you really think the other vehicle will stand a chance Razz FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #389053 28th May 2016 9:07am
RR2008HSE
Wow, I had to go out and check out the car. I'd never seen an airbag disable switch. Hmm. Turns out its blanked on NAS FFRRs. I guess it's always 'on'.
QUESTION: The warning light always flashes on when I start the car, then it goes out. Is that just a bulb check? Does the light STAY on for a faulty airbag? Thx
Post #389167 29th May 2016 1:01am
mjdronfield
Yours is working fine... Light would stay on in the instrument cluster if there was a fault......
..... So why does my light do the same then? I've no fault on instrument cluster..... But still disabled.....? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #389171 29th May 2016 5:49am
RR2008HSE
Phew! Thanks Bow down
Do you have an IID (or similar) to check to see that the airbag is activated and whether it's logging a fault? I don't think they're very user-serviceable. You don't want an airbag in the face while you have your head in the dash poking around. Shocked
Post #389241 29th May 2016 8:26pm
mjdronfield
I had an iidtool for my td6, but not this one. If there was a fault logged, why does the light in the instrument cluster go out?
Don't think I can progress any further without a diagnosis.....
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #389243 29th May 2016 8:32pm
