Home > Technical (L322) > How to enable passenger airbag....?
mjdronfield
The little display near the sunroof switch tells me that the passenger airbag is off.
According to the manual, there is a key lock to turn when you open the passenger door. That looks like it's in the ON position... Turned it to the other position.... Messages says it's still off.....
Any ideas?
Don't want passengers killed to death.....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #388813 26th May 2016 5:27pm
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Is it off when someone is sat in the seat and buckled in? I think it might be occupancy sensing no one (or too light a person) and disabling the airbag
Post #388839 26th May 2016 9:15pm
mjdronfield
I am looking at the display when the ignition comes on...... There is no one in the passenger seat, so will have to borrow a person and do a test...... Didn't think it was that intelligent.
What if a nice young good looking lady was to parachute in through the sunroof during my journey? The air bag would still be disabled..... Does it only check on startup.
Good point though..... I will give it a go.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #388841 26th May 2016 9:24pm
I don't mind popping round and checking your airbags, nice solid wall at the end of your street.... Whistle Whistle
Or shall I send my mate round, that's a parachute she's holding.... Thumbs Up
 Pete
Post #388859 26th May 2016 11:19pm
I'm probably teaching my granny to suck eggs here but does the light come on at startup but then go out five seconds later ? because they do that as part of the self test . 2008 MY Supercharged
Post #388866 27th May 2016 2:42am
mjdronfield
Censored Pete, whilst I appreciate your offer, I'm not sure she's gonna fit through the sunroof.... Thumbs Up
It's the message near the sunroof switch Axle..... Not in the cluster.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #388868 27th May 2016 3:44am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
She has her own airbags!!!!!
No need to enable them!!
Rolling with laughter
Post #388874 27th May 2016 7:50am
mjdronfield
Tried with someone in the passenger seat and it's still the same.....
Can a setting somewhere override the key switch airbag on/off ?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #388934 27th May 2016 5:32pm
this is from the 2006-2009 WM but it should be the same for your year Mark,
hope it helps. ... - .- -.
Post #388935 27th May 2016 5:57pm
mjdronfield
So it's something else that's broke then.... Censored 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #388936 27th May 2016 6:01pm
Personally if you can turn the pass airbag off in a vehicle I tend to.
It means should someone shunt you and the front bags go off the passenger one doesn't write the car off as a lot do when they take out the dash panel and require about 10+ hours and a very expensive dash to replace.
It's getting more common for cars over a few years old to get written off when the airbags deploy as not only does the airbag ecu often need replacing (£££) the dash does and the screen which then costs even more mega bucks in labour alone. A few bodyshop owners I know do the same in their own cars and they drive much more expensive machines than I! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #389013 28th May 2016 12:39am
Shocked I'm going to pretend I didn't read that . 2008 MY Supercharged
Post #389020 28th May 2016 7:27am
oh dear Will Rolling Eyes ... - .- -.
Post #389023 28th May 2016 7:33am
If your sat properly away from the dash and have a seatbelt on then you'd be fine.
Yes you might have a sorer neck but hey ho your neck is still going to let your head fling forward till it hits the airbag if your that close and then bounce it back to your seat... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #389024 28th May 2016 7:34am
https://www.lawyersandsettlements.com/laws...0k8PvR4WnM
With the amount of recalls on vehicles and good old landrover quality and care about older stuff it's upto each driver to be aware of the risks..
Even Honda can't get it right so what chance do we have lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #389027 28th May 2016 7:38am
