Home > Maintenance & Mods (L322) > headlight led upgrades |
AzizRR Member Since: 08 Feb 2016 Location: Muharraq Posts: 54 |
hi there,
28th May 2016 10:34pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I have fitted cob led`s for the outer bulbs. You need to overcome the constant flashing caused by the cars bulb testing system. This can be done with a relay and load resistor on each side quite easily. In my opinion they are excellent, I had similar on my P38 before. Ensure your headlamps are aimed properly. The bulbs I used are similar to these....
29th May 2016 2:44am |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Bear in mind that no LED bulb can match the characteristics of a filament bulb, so an LED bulb will spread the light and generally reduce the intensity - this is often not noticed due to the difference in colour temperature. Also worth knowing that the warmer colour temperature and excellent colour rendering of the halogen bulbs is better for the eye. Visiting from DISCO3.CO.UK
29th May 2016 8:23am |
I disagree, the light intensity is massively greater and further reaching but understand any technical or legal argument will no doubt prove me wrong. I speak from real experience, in my opinion they are just better. 2007 TDV8 VSE
29th May 2016 9:25am |
Actually, I was forgetting we're talking standard wattage bulbs, so the intensity is not necessarily reduced (but could still be), but neither is it increased as lumen figures would suggest - the LEDs emit a lot more light, but it is more scattered by their size and the fact they aren't placed on the focal point. In terms of how far one can see, this is less about overall intensity and more about beam - a wider spread beam will detract from long distance vision because our eyes balance out the light levels they are receiving.
29th May 2016 9:41am |
Again I disagee, they light distances far in excess of halogen and genuine hids but know on paper you can easily prove me wrong. 2007 TDV8 VSE
29th May 2016 9:51am |
Which is the whole point - not everything can be determined by looking; not least, the placebo effect is huge. However much you may think they allow you to see much further, they actually don't. I'm not trying to be difficult and have no reason to be dishonest about it; I'm just trying to spread a little clarity in an area where the consumer is extremely vulnerable to bogus claims by manufacturers. Visiting from DISCO3.CO.UK
29th May 2016 10:03am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
+1 Agree
29th May 2016 8:29pm |
In that case, Alistair, yes, I'm sure it's a real difference, because the LED probably did have a lot more to offer over the torch bulb.
30th May 2016 8:27am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7939 |
I can just about follow that |
30th May 2016 9:35am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
I had a Phillips Xenon kit in my FF’s full beam and the light was INCREDIBLE!!! Probably illegal but never failed an MOT
30th May 2016 10:14am |
That would make sense, Craig, as an elliptical reflector is designed to converge the light on one point and then have it aimed by the lens (rather than aligned in a near parallel manner by the reflector), so the scatter was probably compensated for.
30th May 2016 10:53am |
The easiest way to get rid of the flicker on sidelamp and rear lamp LED upgrades is to either leave the lights on all the time when driving or enable the Canadian or Scandinavian light policy in the CCF FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
31st May 2016 8:11am |
Craig, can you recommend me a bulb for full beam? That would not flicker or cause headlight lens damagae? Thank you |
10th Jun 2016 12:19pm |
