Home > Technical (L322) > Technical Bulletin; Smokey TDV8 Engine Modification
Baltic Blue
Is this issue likely to cause any problems passing the smoke test in the MOT?
I have only seen clouds of blue smoke when I have really floored mine in lower gear. The revs never get high enough in D.
Post #389125 28th May 2016 5:53pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Mine has now had a modification based on the service bulletin. The information from LR dealer was vague on what had been done, I was told it was a oil drain pipe modification to the second turbo and a DPF regeneration. I have nt been able to look under the engine to see if anything was visible. The work was not covered under warranty as its an inherent defect but was covered by land rover as a goodwill gesture. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #392772 23rd Jun 2016 1:23pm
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
My 2009 TDV8 always smoked when the right foot was planted hard but recently it got much worse. No noticeable decrease in power - or so I thought. Noticed a bit of oil around then nearside intercooler hose and mentioned it to main dealer when it went in for a service in March this year. They found nothing. Smoking got worse and took it to my local independent. Offside intercooler hose split and was blowing oil across to the nearside hose! Quick rear with gaffer tape to get me home until the new hoses fitted the next day. The difference in performance is incredible and I'm no longer lying a smoke scree like a 2nd world war destroyer.
Post #392858 24th Jun 2016 7:40am
Different engine different ( common ) problem . 2008 MY Supercharged
Post #392867 24th Jun 2016 8:34am
