Home > Technical (L322) > Hi guys
missbelle
2002 Range Rover Vogue 4.4 V8 Alaska White
Hi guys
Hi Guys need some help here, after finding what I thought was the perfect L322 and paying a good price it has had one problem after another inc stripped spark plug hole and misfire fault all now sorted, 2 days after buying it came up Air sup , HDC,ABS failure, took it to a guy who had the correct diagnostic tool and he said it was prob a break in the wire between an abs sensor and the ecu, my partner put a snap on machine on it and the O/S/F wheel sensor wasn't reading so changed the sensor (had yo drill out) and he phones me saying cars all perfect all lights out and car goes up and down. On the way home is when it blew the spark plug clean out the head so he repaired that and now when the car starts it just reads Air Susp Innoperative, no warning lights and HDC ABS warning etc just the ASI warning in the digital display and no orange light to indicate at what level the car is at yet it was working a week ago when parked up, HELP any ideas
Post #388970 27th May 2016 7:55pm
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
dam id be backing that hope you get sorted 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #388973 27th May 2016 8:00pm
mzplcg
Get the battery tested. These cars are notorious for needing a large and well charged battery. If it's the original chances are it's below the required condition for a FFRR and if it's been replaced at some point it may have been with a battery which doesn't have the required CCA or AH ratings.
If the battery voltage dips badly during cranking the engine over it can put the various ECUs into a real pickle. Volts should be about 14.4 running and at least 12.4 when off. No lower than 11 volts during the start.
Preferred option on here seems to be the 110 AH Bosch or Varta units.
Post #388976 27th May 2016 8:09pm
missbelle
Hi guys thank you for getting back to me so quick battery has been tested and sits at 14.4.... even after sitting for 2 weeks she turned over as quick as expected... any other ideas lol
Post #388977 27th May 2016 8:16pm
Rangeyman
It is back to diagnostics am afraid .!
Post #389092 28th May 2016 3:55pm
ebajema
I'd suggest to start checking all the posts on air suspension here and see what could be wrong. Sorry to not have better news. Start with the simple stuff, listening for any leaks (does it lose height after standing for a while, mine lowered itself a little bit before the front suspension airbag really gave up). Check if all hoses are fine.
Start looking at the compressor, has it been refurbished, if not probably time to do it. Little things like the air vent filter clogging/rusting can cause issues etc.
Check wiring again, connectors (water ingress etc.), earthing.
Hope you find the problem soon and that the solution is cheap and quick Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #389097 28th May 2016 4:06pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
I dont think the compressor is at fault as when it was going up and down it was much faster than my L322 which i wasnt impressed with, I think we will try my brand new Bosch battery in it over the weekend. Just to add insult to injury the cable from outer door handle to lock snapped yesterday om Missbelles car !!!! God I hate that car. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #389102 28th May 2016 5:15pm
Worth a battery disconnection procedure, then a lock to lock on the steering to clear the lights, that should reset everything.
Failing that, need a full diagnostics for all the fault codes, then clear all the faults, run it, then if it recurs, run full diagnostics fault check again and see what has come back. Then start to investigate these one by one. .
Post #389116 28th May 2016 5:57pm
JohnnyDangerous
Tried Bat disconnect both leads and touch ends together, doesnt appear to register a fault code on my snap on scanner which picked the wheel sensor fault up straight away. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #389117 28th May 2016 5:59pm
I assume you have checked the air suspension fuse?
If not Fuse 57, 15A. Thumbs Up
Post #389128 28th May 2016 7:36pm
JohnnyDangerous
ERR yes of course we did or will in the morning Laughing One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #389155 28th May 2016 11:22pm
