Home > Maintenance & Mods (L322) > 2006 SC, Suspension fault after tire change.
Stormbringer
Norway 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Getting a bit confused...
I got the Suspension fault after a tire change.
Plugged in the IIDTool and got this fault:
Cleared the fault, but it returned immediately.
Ok, a faulty sensor, no problem. Smile
Changed the sensor, same problem. Sad
Ok, a faulty wiring then, fitted a EAS Sensor Repair Harness.
Same problem. Shocked
Other tings to notice.
1. It will go trough all height modes without problems.
2. If it sits overnight, the rear right will be lower, but not to the bump stops.
3 .If i pull the fuse to the compressor, it will not lower any of the corners(measured over 3 days), so i don't think i have an air leak.
4. The front left suspensionis about 15mm higher than the right one, both rear are the same height.
5. If i run live values for current height form the IIDtool, all values will change in sync when i raise and lower the vehicle.
6. Deflated all airbags with the IIDTool, all corners deflated equal and to the bump stops, raised back to normal height without problems.
Any tips? Rolf Johansen
2006 RR 4.2 SC Autobiography
1999 Defender 110 TD5 (sold)
LR S1 86" 1954 (sadly sold)
Post #388677 25th May 2016 9:59pm
Try working your way through this lot.... Thumbs Up Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #388681 25th May 2016 11:22pm
ebajema
I notice that the IID shows a 15 mm difference in front height. Maybe that is the problem. My suggestion is to check both heights in real life and bring them to the same height in the software if that works.
My reasoning is that the software would allow for some difference between left and right and front and rear but when that goes over a certain value (close to 15 mm maybe) it triggers the fault. Hence my idea to bring the heights closer together, with the car sitting on a level piece of ground and the actual suspension heights at the correct measured value.
I think it was Joe90 that did a description on measuring height correctly and how to adjust it. MY 2010 5.0 SC Galway green and sand interior!!
Post #388685 26th May 2016 4:25am
There is a 9mm tolerance in heights as standard, the system can't tell if it is level, only if it is within the tolerance per wheel that has been set.. i.e. it doesn't have a build in spirit level...
Being 15mm out won't worry it at all.. Thumbs Up Thumbs Up Pete
Post #388745 26th May 2016 10:41am
Stormbringer
Thanks for all the help guys. Everything is now back to normal. Very Happy
Measured the cabling all the way to the suspension module, all ok.
Did a full calibration and after that everything was ok. Thumbs Up
So was the sensor faulted in the first place? Put the old one back again, and it gave the same error, swapped in the new one, fault gone.
So a faulty sensor giving me the same error as incorrect height calibration fooled me. Smile
Gotta love British humor.
One a side note. After everything was ok the LCD display was stuck in "Off road" mode.
The solution to this was to deflated all corners, and re enable EAS. Rolf Johansen
Post #389056 28th May 2016 9:38am
ebajema
Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #389057 28th May 2016 9:45am
They do have a mind of their own.... Rolling Eyes Rolling Eyes Pete
Post #389058 28th May 2016 9:53am
