Home > Technical (L322) > 4.4 tdv8 oil level indicator.
Baltic Blue
When I try to check oil level display says not available.
Any clues where to start looking?
Post #388456 24th May 2016 11:26am
ignition on [no engine start]
and it should show in the menu.. ... - .- -.
Post #388470 24th May 2016 12:42pm
Baltic Blue
It shows in the display but as though it has no oil in it.
Ie, off the bottom of the scale.
Is their any way to dip stick it as a fail safe??
Post #388472 24th May 2016 12:57pm
i dont think there Michael,
have you read this from the owners manual [link in wiki]
Post #388474 24th May 2016 1:13pm
Baltic Blue
Thanks Stan Panic over.
I have to drive to my local Tesco car park to find somewhere flat to check the oil level.
I obviously didn't leave it standing long enough before checking oil level. (Must need at least 10 minutes)
Just re- checked and all OK.
Post #388478 24th May 2016 1:21pm
Thumbs Up ... - .- -.
Post #388480 24th May 2016 1:27pm
wealy
It shouldn't give a reading at all if it is not ready? It takes at leased 10 minutes.
Post #388561 25th May 2016 7:45am
dazza1983
Do you check hot or cold? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #525662 21st Aug 2019 10:42am
Baltic Blue
3 years on from the original post and we are all older and wiser Rolling with laughter
You can check oil level cold, ie before starting engine... and hot, but you have to either wait 10-15 minutes after stopping engine, or open bonnet and double press the cruise control reset on the steering wheel whist display is showing “ not available”
Post #525665 21st Aug 2019 10:51am
DrRob
Perfect summary of it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #525667 21st Aug 2019 11:01am
rtkeane
Ireland 2011 Range Rover Vogue TDV8 Zermatt Silver
Thanks worked like a charm 2011 L322 TDV8 Vogue Ipanema Sand, Ivory & Black
2016 Alfa Gulietta
2004 Discovery 11 Landmark (gone)
2007 A6 SE 4.2 FSI (sleeper gone)
1994 S500 (gone)
Assorted Ranger, Navara
Great Wall Wingle
1994 Isuzu Trooper
Post #600870 16th Jul 2021 12:15pm
