![]() | Home > Maintenance & Mods (L322) > Where's the logic? |
You could also ask how a humble Stop/Tail bulb could bring the mighty Discovery to its knees, but it can. |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Haha really? No way! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
HDC uses abs, so probably disabled if fluid low....
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
According to Storey Wilson (RSW Allcomms) , the ABS and Air Suspension computers are closely inter-related so a fault on the ABS system will almost always trigger an air suspension fault warning too. Current Fleet:-
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Yep, but it is logical; bad bulbs cause electrical noise on the brake circuits, which in turn upsets ECUs. It can happen on other "premium" vehicles too. ![]() There are always all sorts of faults that can trigger each other because of the way the systems are designed to work together. Easy to see it as a PITA, but it's what makes LRs work so well both off and on road. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
I would also be removing the covers on the LHS underneath to check the condition of the brake pipes (that is the tank cover and the flat covers on the long run from front to back) If your pipes have not been changed they are likely to be quite corroded and leaking. 200ml is a lot of fluid to lose so keep an eye on the level.
