Home > Technical (L322) > Driver door central locking mechanism |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Does it work with the key? |
20th May 2016 8:45am |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 437 |
I haven't tried with the key - will try that next time this happens! |
20th May 2016 11:42am |
Yes, the door will unlock when I use the key in the lock.
20th May 2016 2:57pm |
RAVE sayeth:
So, from that I'm reasoning that : 1. The actuators work 2. The additional Hall sensors for the key work 3. So, it's the Hall sensor in the latch not always reporting the door status correctly. Which could be the sensor or wiring. I'd start with the loom from the door to the pillar. Ian |
20th May 2016 5:48pm |
Thanks Ian, this is a new territory for me - I think that I need to investigate a bit into this.
20th May 2016 10:55pm |
There are a bunch of wires going between the door and the rest of the car. These can get pinched or chafed. This is true on many cars, not just ours! They usually are run in a flexible tube, take a look and you should see it. I've not had to check mine, but I'd expect to need to remove the door trim panel to look. Maybe someone else can chip in on that.
20th May 2016 11:03pm |
