Home > General > List of Owners with IID prepared to help others ? |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Thanks for clearing that up Range Rover quotes.....
11th May 2016 1:06pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Thanks for the clarification, Alistair and Lost for Words. |
11th May 2016 4:33pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Another issue would be the knowledge to use someone else's IID. There's always a number of meaningless fault codes in there, even when everything is working properly. If you're just borrowing it for 5 min, it would be difficult to find the important errors amongst the unimportant ones. |
15th May 2016 9:43pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
ive bought a secondhand britpart iid tool (non BT). its just the matchbox unit, no leads. it was an l322 and then a sport id was added. will it still work on l322? and what do I need to connect it. -I bought it secondhand, and have not yet had chance to read up on the operation etc. thanks. (p.s. surrey area) |
15th May 2016 10:17pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
^^^ That is a question for GAP don't you think , but I think BMW based L322's are different and the tool isn't compatible . 2008 MY Supercharged
16th May 2016 12:38am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
I'd quite happily read fault codes for forum members North of the border |
16th May 2016 6:17am |
Not sure if it will work. The non-BT has very little memory. I thought it has enough for only one model. But if you're switching and paying Gap for a new user, I'm pretty sure they can help you. The speed and accuracy of their customer service is some of the best I've seen. Anywhere. Ever. |
19th May 2016 1:22am |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
I too have the icarsoft i930 and also an Autel MD802 All System and would be willing to help other forum members out. |
20th May 2016 4:21am |
