Home > Technical (L322) > 12v Socket In Boot Always Live ?.........or is it ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7775 |
The manual states that the socket in the boot is always live.....
18th May 2016 4:32pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Do you have a phone power charger with an LED in it? If you lift up the parcel shelf and plug that in you can easily see for sure by revisiting the car a bit later and peering through the tailgate glass to see if it's still glowing or has gone out.
18th May 2016 4:48pm |
I bought the battery monitor from the same company who made my cool bov. It has a male socket one one end and a female on the other for 12v appliances, and it has an LED when it has power. I happened to notice it power off at the same time as the dash screen. Shut the car up and locked it, still nomLED, so it ain't gonna run my cooler unless the engine is on really, irrespective of what the manual says.....
18th May 2016 4:54pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
craig replied to another query re this and apparently the boot socket is not permanent live after 2009my ... - .- -.
18th May 2016 5:20pm |
....so looks like they therefore omitted to update the user manual. 2006 4.2 SC
18th May 2016 5:51pm |
peachy.......
18th May 2016 5:57pm |
Summer's over - You won't be needing that cool box. It's the FBH that you need to be working! 2006 4.2 SC
18th May 2016 6:01pm |
http://www.fullfatrr.com/forum/topic32623.html
18th May 2016 6:09pm |
2010MY onwards the boot socket goes off when the car goes to sleep. However, you have permanent 12v in the OSR cubby in the form of a fat 100a cable going to the front. I just wired mine into that, with appropriate fuse I might add. |
18th May 2016 6:13pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
and wake up to a nice flat batteried FFRR no doubt. Agree would at least be good to have the choice. .
18th May 2016 7:14pm |
I leave the Engel in there all the time and I've never had a flat battery. And it doesn't get used every day, I have the work hack for that. |
18th May 2016 8:38pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Since we are on the topic and I have an 2008...this socket should work for me as a permanent cooler option.
19th May 2016 12:18pm |
^^? 2014 FF Autobiography 5.0 SC
20th May 2016 12:08pm |
I bought the Waeco Tropicool TCX 21. It's German, so must be the best.... 2011 Range Rover Vogue SE 4.4 TDV8
20th May 2016 12:25pm |
