Home > Off Topic - Other Cars > DIY body spraying |
OK, having sprayed a few cars over the years (I'm no Picasso mind you) I will offer the following advice.
17th May 2016 7:31pm |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
Can I add the appropriate health warnings about 2 pack paint please? Thanks 2007 Vogue TDV8 with 255/55/20's fitted |
17th May 2016 9:10pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16299 |
Ajac, if you have the time? Repair & prime everything that needs priming then boot the car out into the weather for a couple of weeks... This way if any of the repairs are going to sink? They will do it before you spend your time & money painting the panels only to find some of the repairs will sink! Dooohh too late then... They do need to be outside though getting hot, cold, wet & dry for the sink ages to happen sir |
17th May 2016 11:29pm |
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 |
Hi ajac,you re quite right about paintwork being a minefield i ve been a paint sprayer for`30 odd yrs [feel old reading that ]used all sorts of paint inc waterbased.Dont cut corners on your prep work, its worthwhile in the end.In answer to your questions-etch prime the bare metal/filler,1or2 light coats. Etch has no build qualities so a good primer [ two pack ?]should be used, it can air dry overnight, depending on which hardener you use[ fast / ex fast]. If your paintwork is sound you can just prime the repaired areas.As for flatting,depends on a few things,finish sanding the filler with p180 then p400 onto the surrounding area to give a good feather edge.As previously said, you can use scotchbrite to key the paint or flat it with wet 400 no coarser.The surface should be smooth,scratch free as the basecoat will not cover up all. You could dry sand all the paintwork but we re getting into needing quality sanders ect ? Wet flatting is more forgiving but messy.You will need a good panel wipe or degreaser and tack cloths. Your paint supplier should give you advice on requirements.I would use solvent base coat over waterbased .As jonnyboy has said, two pack paint is dangerous [ carceongenic]An air fed mask should be used,its v unpleasant if fumes are breathed in .Gloves and all skin covered too . The mist will stick to everything including next doors car if the winds in that direction] I ve only just touched the subject but i hope it helps. good luck. Ray |
18th May 2016 11:39am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1656 |
Many thanks Gents, very useful info especially the health matters.
18th May 2016 12:12pm |
