![]() | Home > Technical (L322) > Turbo actuator |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Not sure about on switch off but there have been a few posts on here about them doing a full sweep at start up but they can get gummed up and this can cause an engine system fault if they are restricted. You can apparently free them off and get 3 in 1 sprayed on there to solve the issue. |
STU TDV8 Member Since: 03 Apr 2016 Location: norfolk Posts: 65 ![]() ![]() ![]() |
Had the turbos rebuilt they were working fine when I removed them now I've refitted them it's low on power low down and engine fault light comes on . Passengers side moves about 12mm and drivers side moves about 2mm when you turn the ignition on but they don't do a full sweep ?? |
Well that's certainly not right! I'm no expert but from what l have read at start up the arms go through the full motion maybe more than once from memory so they should both move at least the same amount. Have you had the codes read? That should give you a good idea of what's wrong if the engine management light comes on! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Oh dear... No thats NOT right sir... They should go through the full range of movement |
Olly-Ibiza Member Since: 08 Jun 2016 Location: chester Posts: 49 ![]() ![]() |
Who rebuilt the turbos, I know they have to be calibrated once rebuilt and there are very few places with the kit to do it |
Owens development's rebuilt them ... |
Do they have the electronic calibration kit to do it? Iv head loads of people have turbos rebuilt or new cores fitted then just get endless actuator fault issues |
No they said they couldnt test it |
The guy that rebuilt my turbo had to send it somewhere to get it done, I can try and find out where he sent it |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
And for this very reason, I only supply brand new OEM turbos ![]() |
Dont suppose you have an old actuator laying around for the driver's side from an old unit do you mikey ?.. |
Soon as you undo the bolts that hold the actuator on you will lose the calibration so another actuator won't be much help |
Dont work now so can't be in a worse situation ?.. |
