Home > Technical (L322) > Heating not particularly warm on "auto" |
Mmmm if it was an older car it would be simple, the heat sensor in the panel got clogged with dust but since it is such a new car I think there may be an issue with said sensor OR there is something wrong with the control motor of the flaps but again, that is something for the older cars usually.
17th May 2016 1:06pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Is it possible your car is doing what it is supposed to?
17th May 2016 2:05pm |
pmurgatroyd Member Since: 07 May 2016 Location: Northants Posts: 7 |
It's certainly possible.. I will have to measure it
17th May 2016 2:30pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
I found the same thing. Even if you turn up the temperature it doesn't really do much.
17th May 2016 2:52pm |
Pretty much the same answer I just got from the dealer over the road!
17th May 2016 3:08pm |
Berty Member Since: 04 Jan 2016 Location: Leeds Posts: 73 |
Remember to adjust the heater wheel under the central locking Button middle vent ( on 2012) to either hot or cold depending which you want as that makes a massive difference if set to the opposite |
17th May 2016 6:24pm |
