Home > Technical (L322) > L322 V8 - no fuel pressure until cranking! No Residual! |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
That fuel has to be going somewhere.
17th May 2016 7:18am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
As above, fuel pressure is dropping off due to it escaping. Either internally (e.g. failed non-return valve in fuel filter/pressure regulator or stuck open injector) or externally which hopefully would be a bit more obvious!
17th May 2016 4:17pm |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
No smoking at all when it starts after hot start issue. The fuel pressure when running was about 3 bar (40 psi).
17th May 2016 4:23pm |
