Home > Technical (L322) > 2012 Vogue oil pump problems?
mjdronfield
All the ones I mentioned were of the same issue, oil cooler - to answer a post above.
Def a common issue now..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #387393 16th May 2016 5:10pm
GraemeS
Thanks. It would be good to know if the fracture is always at a fitting which presumably is fatigue from vibration in case something can be done to alleviate the movement. The original part number doesn't seem to have been superseded so presumably the same failure is going to re-occur in another 4 or so years.
When I get an opportunity I'll have a look for any connecting pipes that might cause fatigue.
Post #387431 17th May 2016 2:39am
Allan
+1
Had a similar issue earlier in the year with oil down the back of the engine. Main dealer diagnosed as the seals on the turbo oil feed pipe. Apparently a known fault and there is a new part with better seals available. Replaced under warranty but it didn't fix it.
Still leaking oil and the vehicle smells of hot oil after a journey and occasionally produces mist on cold nights! Took it back in and diagnosed oil cooler leak.
Vehicle is in as we speak with the oil heat exchanger being replaced. Fortunately it's under warranty as it won't be cheap.
Excellent service from LR as always.
Post #430570 9th Mar 2017 12:39pm
mpirie
I had leaking seals on the turbo pipe too, but noticed that i have oil in the coolant so as soon as the replacement cooler arrives from Dan, I'll be replacing it.
The oil cooler comes as a kit with filter and seals at £350.......not a cheap fix, but cheaper than letting it continue to contaminate the coolant !!
Post #430571 9th Mar 2017 12:48pm
Baltic Blue
Dave,
Oil pump is No.14 in this picture if it helps.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #430582 9th Mar 2017 2:23pm
