![]() | Home > Technical (L322) > 2012 Vogue oil pump problems? |
Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187 ![]() ![]() ![]() |
Ok was all set to pick up the car, but thought I'd phone just to make sure all was well. Its a 5 hours round trip for me. I won't mention the dealer just yet.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
What car? |
2012 Vogue 4.4 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Mine had a massive oil leak down the back of the engine and over the gearbox as the oil cooler was cracked. I know you said pump.... The oil cooler is in the V.... No oil in engine, as its gone into the coolant system. £1097 later all is well.
Thanks for the replies gent's. i have a free app on my mobile that records all calls, i listened to the call and he said a hair line crack in the top of the oil pump, he said the oil was weeping out of it, so no rapid loss of oil. I'll check the coolant to see if there's any oil in it, but how would this be done as the oil would float on top of the coolant, so just looking in the expansion tank would be no good would it?
You'll know.....
OH i see lol, hope i dont see this, thanks for your help mate |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 ![]() ![]() ![]() |
Funny that, my 4.4 tdv8 2012 has just come back from a new oil cooler change, that had a slow weep on one of the fittings. It slowly filled the V up in the center of the engine, and then started pouring down the back of the engine! It looked pretty bad, but had not lost a lot of oil.
Sorry for the question in advance , but like i said i haven't picked the car up yet.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Just lift it up at the front and pull towards you. ______________________________
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
I can't recollect if it was on here or another forum but there was some discussion regarding Saxton's customer services and back-up; may be worth investigating and making your own mind up.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
Do you know if the others failed for the same reason? |
I called them this morning for an update, i was told its the oil pump thats cracked, They have the new one they ordered from LR. but it's a very labour intense job fitting it, i'd really like to check if a new oil pump was indeed fitted, can anyone tell me were the oil pump is on a 2012 4.4, with a pic if possible please |
Mactech Member Since: 27 Jun 2015 Location: Biddulph Posts: 126 ![]() ![]() ![]() |
Just taken my 2012 4.4 TDV8 for service this morning with an oil leak in the V of the engine and oil dripping over the gearbox and exhaust. It has been getting worse over the last couple of months, but I've not had to add any oil.
