![]() | Home > Technical (L322) > Steering wheel auto raise & lower |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
Peejay, i also have this issue so will be following this thread with interest. Terry 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Can you get the diag codes read? Might be handy. |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 ![]() ![]() ![]() |
I don't have an iidtool, I guess that's what's needed to read codes? I was thinking of getting the iCarsoft tool as recommended by another member - I assume that could read fault codes? Cannot justify the cost of the iidtool as it's far too capable a tool for my use! |
Yes, the iCarsoft tool can read and reset codes, also show live data. Unlike the IID tool it can't tweak settings, and other tools can get data into graphs and stuff. I have an iCarsoft and for the money it's good. |
Thanks for that Mr Spock, so wth the iCarsoft tool I could reset the service reminder date for instance? If so, can I just delete the reminder or would I be able to enter a different code? Excuse my ignorance but this is all new to me! |
No, the service reminder doesn't seem to be a fault code. However, that can be cleared anyway without a tool. It's in the wiki on this site:
Ian, that appears to be for models 02 - 05? Will it work for my 09? |
I don't think it will work post 2005 or 2006. Google suggests this may work:
Had a go at this yesterday evening Ian and managed to get a message about oil service but the one I wanted to clear was the service reminder and as you say, it's not possible to do that, so I guess I'll just have to put up with it telling me every time I turn on!
Still can't find a solution to my steering wheel odd behaviour, just wondered if anyone has any ideas on how to cure it?
Im not sure an iid tool will help with the problem apart from enabling you to turn off the tilt function. I also have the same issue so hopefully someone with greater knowledge than us will come along with the magic cure to our problem. 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I had this issue around 6-7yrs ago on my '56 RR VSE . The steering column lifted ok when the engine was turned off, but when I turned it on, the wheel just kept going down until it hit my legs. I had it fixed under warranty and I think it was the module that controls the wheel and seats was either replaced or the potentiometer in the steering wheel was recalibrated. Can't remember exactly which (unless I posted it on this forum of course!). Whatever they did, it never happened again. Steve
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8373 ![]() ![]() ![]() |
You can only reset the later cars service lights with a diagnostic tool....
Peejay, turn off the function in the dash???
