Home > Technical (L322) > Reverse signal for audio system
Beemergriff
I'm new to the forum, and have looked at a few threads about audio systems but none answer my question.
L322 TD6 2004 SE model with low-level audio - all in the dash apart from CD changer in glovebox, with nothing in the boot compartments.
Currently have wireless reverse camera to a separate lcd screen (powered from lighter +12v feed) that works fine.
I have an Erisin ER7053 unit ready to fit, but it has connections for a Reverse signal - to switch the unit into video mode for feed from a camera. Where can I get this from? For my wife's Freelander, I just spliced into wire from reverse switch fitted on the end of the gearbox, but L322 doesn't have that.
It also asks for Brake input, to prevent viewing DVD while moving - that can be disabled but I would like to do it right.
I'm competent with mechanics and electrics, not so good with electronics/CANBUS etc.
Any advice appreciated, thanks.
Regards
Andrew
Post #386057 9th May 2016 10:25am
Take a feed directly from the reverse light wiring going into the lower tailgate in the spare wheel well Thumbs Up
Post #386058 9th May 2016 10:29am
Beemergriff
Thanks.
I had hoped there might be a connector around the gear lever that I could link into, but I can go from the boot under carpets etc to the dash area if that's the best option.
Post #386062 9th May 2016 11:38am
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
let us know where you find the reverse light cable if you do please, a couple of pics would be great
going to order my reverse camera soon luckily my cable loom ends in the boot so not far to go
Post #386102 9th May 2016 3:43pm
Maybe I'm being dumb here, but you have to feed the signal cable from the camera anyway, so not exactly a hardship.....
When I did mine - I was lucky enough to have tow electrics so just tapped into that.
Post #386103 9th May 2016 3:48pm
Ohwhatalad
Depends If op has wireless rear cam or not
Post #386108 9th May 2016 4:17pm
Fair point - I had made that assumption Embarassed Thumbs Up
Post #386114 9th May 2016 5:18pm
Beemergriff
I already have the wireless camera mounted and sending to LCD display, but now want it to show on the aftermarket head unit I am fitting to replace the 2-line display (that has the usual defective pixels anyway).
If I could find a feed from the reverse light somewhere in the dash area, that would be best. Having looked this afternoon at what is involved to run a single cable from the boot to the dash, hidden properly under carpets, I am now more inclined to put a switch in a +12v feed and switch the unit manually when I reverse.
Parking is OK, it's trying to hitch my trailer that is a pain.
Thanks for the replies, and I will definitely take pictures and post what I do.
Regards
Andrew
Post #386121 9th May 2016 5:45pm
Did you look at taking it over the doors rather than under ?
I did some wiring in my old one & recall tucking cable into the door seal trim was quite straight forward.
Post #386122 9th May 2016 5:51pm
both rear and front sill plates come off and theres sort of trunking where you can lay wires.. ... - .- -.
Post #386123 9th May 2016 5:56pm
Be careful going over the top that you don't obstruct the curtain air bags
As Stan says going up the sill is an option but it's hard to get anything other than a very thin wire past the "B" post without it being crushed somewhere... lot's of shots in this thread of what it's like....
http://www.fullfatrr.com/forum/topic29219.html Pete
Post #386432 11th May 2016 4:07pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I am not sure on the RR, but it is normal to have a reverse feed to the rearview mirror to inhibit the autodip function when reversing (ie clearer picture)
When the instrument pack receives this message*, it outputs a signal to the LCM (C2040) via
the I Bus on a WSY wire. When the LCM (C2039) receives a reverse gear selected signal,
it provides a feed to the following on WY wires:
􀁺 The RH reverse lamp (C0455)
􀁺 The LH reverse lamp (C0472).
*from the ECM via the CANbus, signifying that reverse has been selected
Post #386853 13th May 2016 12:30pm
The reverse lights are fed from the LCM which is located behind the side panel in the drivers footwell.
They are fed from a White / Yellow wire 0.75mm˛ running from the LCM to the rear of the car.
No need to go to the back of the car to pick up a reverse feed, just tap into the W/Y wire at the LCM.
I used it for something but unfortunately I can't remember what. Rolling Eyes
Post #386875 13th May 2016 3:41pm
