![]() | Home > Technical (L322) > Is it the FSR Failing |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 ![]() ![]() ![]() |
Hello all
Thanks for the prompt reply, it definitely isn't the AC Gas as this has been recently done and the centre vents blow icy cold when set to cold on the mixture wheel.
Rilla Member Since: 29 Feb 2016 Location: Douglas Posts: 58 ![]() ![]() ![]() |
I have this issue aswell, looked thro the manual to make sure it wasnt a button i needed to press buty cant find anything to try and cure the issue. Its like the temp setting dials serve no purpose, and the only way to adjust temp is on the centre dial between the 2 vents.
To clarify things further:-
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
I think the FSR is only controlling the fan speed not the blend. I can think of 3 causes:
Thank you Mr Spock, I have sent you a PM regarding codes 2003 V8 Vogue in Silver |
Did you get an answer to this at all?, mine is still the same, and also discovered in no matter what temp is selected on any of the climate controls (front and rear) the rear compartment only gets hot air. REALLY hot air.
Hi Rilla
Bummer.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8348 ![]() ![]() ![]() |
There is one line in Rave that I think is worth a check...
OK thanks for the info. I can try that this week as I have a friend with a working one I can swap and test.
