Home > Maintenance & Mods (L322) > New RR
robval
United Kingdom 2002 Range Rover HSE Td6 Atacama Sand
New RR
Hi to everyone, Just joined. Bought my 1st RR 6 months ago its a L322 HSE 3.0, 02 reg done 64000 miles. I live in Derbyshire. So far the air sus. has gone wrong 3 times. had the comp, reconned, and new sensors fitted,now booked in again for diagnostics. headlamp control shorted out,(£300). stereo amp shorted out, and now the steering wont tilt!!! Is this normal for a RR or have I got a duff one?
Apart from that I love it,
Cheers All, waiting eagerly for your responses Smile Robval.
Post #385907 8th May 2016 12:49pm
Weegie
Welcome
Steering not tilting is a well documented fault. Some info here:
http://www.rangerovers.net/repairdetails/s...troduction also a search on the forum will produce more results.
I locked mine into place at the height that suits me. The motors are expensive to replace. John
GAP iiD BT
Post #385908 8th May 2016 12:57pm
mjdronfield
Welcome. I'm in Chesterfield. I had a TD6 prior to my 4.4 TDV8.
All sounds like the normal issues. Plenty of info on the forum under the search facility.
Don't try and fix everything in one go unless you have spare cash. Sort the important stuff first....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #385910 8th May 2016 1:06pm
robval
software update?
Hi. Thanks for your reply.
My local garage reset the susp. fault and is driving ok at the moment.
But he said the fault code showed up said a software update was required?
Gordon Lamb said to sort it would be £85.00 initial fee followed by labour charges of £118.00 plus vat per hour????
Do you or anyone else know of a way to upgrade software with out paying 200 to 300 quid?
Cheers Robval
Post #386415 11th May 2016 3:04pm
Rangeyman
Not sure about the software update,maybe he is trying to get a few quid extra out of you !
Post #386527 11th May 2016 6:54pm
You can't update any of the ECU's in the BMW based 2002-2005 Range Rovers so I'm afraid he is mistaken.... Pete
Post #386533 11th May 2016 7:17pm
mr_spock
Isn't that TSB0033? Compressor run temp settings? Not an ECU update but changing parameters.
Post #386539 11th May 2016 8:00pm
Can't believe there would be any FF's going around with the old values still in them, but you never know I suppose...
Is it an overheat fault that keeps coming on, if so maybe it does need the new values programming in...
What did they recondition in the pump, if it was just the piston ring it could still be the pump....
Can't believe a so called specialist doesn't know how to read and interpret the settings from the EAS and diagnose what the problem is, I mean it's a pretty simple system and the values are all readable, also they can update the settings with pretty basic diagnostic tools....
Think I'd try a different independent for a second opinion.... Pete
Post #386548 11th May 2016 8:59pm
robval
upgrades
Hi. Thanks for all the responses, will do some more research on this. will post more when I find any out anything.
Cheers
Post #386636 12th May 2016 12:26pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
^--- +1 for Haylands suggestion
Find another Indy before you get your wallet emptied. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #386638 12th May 2016 12:28pm
robval
HI. Ok thanks. Iv`e heard that an IID can download updates, is this true? I dont really know anything about them.
Post #387363 16th May 2016 4:07pm
