Home > Wheels & Tyres > New compomotives 😄 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2471 |
New or used? |
7th May 2016 10:14am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
2nd hand. ______________________________
7th May 2016 12:51pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
Love them! Formerly happymadison1978 |
7th May 2016 12:56pm |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 |
Very nice! What size are the tyres??? Regards,
7th May 2016 2:09pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2641 |
Ooh nice |
7th May 2016 2:31pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
They are the mutts nuts. I love the look they give my RR.
7th May 2016 6:43pm |
They look new but presumably not quite so expensive. |
7th May 2016 8:36pm |
The tyres are 265/60/18s. Which was the size I was leaning toward if ever I could get a set of these. The size appealed to me as its fitted to a lot of Toyotas and so more readily available. It also fits in the wheel well. While the size is right for me, I would have bought a different tyre with a higher load rating. These Coopers only have 110 load rating. My chinese cheap and cheerful HT 255/55/19s have 111 load rating.They have been a good tyre so far.
7th May 2016 11:54pm |
A load rating of 110 translates to 1060Kg, whereas your 'cheap & cheerful' tyres are rated to 1090 Kg - not much difference!
10th May 2016 6:08pm |
Thanks spooky. The tyre load rating exceeds that of the rim, so quite ok. I was more using the rating as a rough guide for side wall strength. I'm hoping the coopers, being ATs, will be stronger.
10th May 2016 6:49pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
The little ad rating of the standard 20" is 109 so make of that what you will. There is nothing that can't be fixed with a hammer😜😜
10th May 2016 7:49pm |
The bigger the wheel the shorter the tyre wall, and so a need for more flexible the tyre side wall (assuming overall wheel size is kept approx constant) to absorb road impact. The consequence of a thinner more flexible tyre wall is lower load rating on the tyre.
15th May 2016 2:19am |
Finally got to fit them after hassles with locking and standard nuts.
10th Jul 2016 12:23pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Turn your flash on.
10th Jul 2016 12:44pm |
