![]() | Home > Maintenance & Mods (L322) > Transmission oil change |
I can't give much advise but which year/engine do you have and how many Km has it done , all this will have some bearing on the advice to follow.
No jacking because there's no chassis crossmember to get in the way.
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Hi
Regarding the plastic sump. Does it come off easy enough. I thought I'd read somewhere it needed to be broken off somehow??
Some of the bolts can be stuck in place and break. So better get a new set of bolts (some kits include the bolts) and gear for removing the broken bolts.
lifeguard 6 all the way , there are no recommended alternatives ![]() Because Ford used the 6hp26 gearbox in the Falcon and Territory here and screwed up the cooling there is a lot of expertise on them available , you might be well advised to talk to an expert locally . 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
Yeah, trying to find a decent place is challenging.
Dint know about the sump pan , the place that did mine didn't say anything but my new one is steel with shiny stainless fastenings |
Can't see it in the wiki, hence all my questions.
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
Assuming yours is the zf 6hp26x box then no you don't need to break the plastic sump to get it off. I recently did mine and replaced it with another plastic sump - I'd rather have an OE part than an aftermarket metal one. As for fluid, I used the Meyle stuff from advanced auto factors (site sponsor). |
