Home > Maintenance & Mods (L322) > 3.6 Oil Drain Using Vacuum |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Where is that ?
5th May 2016 9:08pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Not being sarcastic here... The tube is where you would expect to find the dipstick sir... Left side front (ish) similar place to the 3,6 |
5th May 2016 9:30pm |
Arrrrr wondered what that was?
6th May 2016 6:53am |
What is the best and most suitable vacuum to use ? There are loads on eBay? |
6th May 2016 6:54am |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
I use one called mityvac, although it's not quite large enough for to remove all the oil in one go
6th May 2016 9:58am |
Just checked and the id of the tube is only 5.4mm so a 5mm tube needs to go down there. Thats not much of an id to get the oil oil out, especially if its cold! It must take ages! |
6th May 2016 11:28am |
The mityvac comes with different tube diameters that will fit down most (if not all) dipstick pipes
6th May 2016 11:54am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
a tube doesn't go down the dipstick tube it attaches to the top of it, on the 4.4 the tube is connected to a drain off point at the bottom of the sump There is nothing that can't be fixed with a hammer😜😜
6th May 2016 3:16pm |
REALLY??
6th May 2016 3:37pm |
That's what I was told.... Could have been bamboozled though. Mine has a kinda of bayonet fitting on the top. There is nothing that can't be fixed with a hammer😜😜
6th May 2016 7:10pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
Two questions if I may...
6th May 2016 7:45pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
6th May 2016 8:45pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
I have one very similar to that but only sucks the oil out.
6th May 2016 9:51pm |
Thanks A380 - nice one 405 AB exec seats Baltic and Cirrus
7th May 2016 5:05pm |
