Home > General > How to treat an FF....??? |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
Well I regularly drive it like I stole it and stuff is still bunged up. Mind you previous owners could have done the "damage" because it's bloody awful stuff to shift.
3rd May 2016 6:08pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Pete...totally agree, but given your last company car sported a bloody great blue light on the roof, the opportunity for a Haylands tune up probably presented itself a wee bit more often than most GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
3rd May 2016 6:10pm |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 |
Hi Mick, I would be interested in which charger you use and how you connect it. I have a CTek which is excellent for my wife's under-used Merc SL350. But when I connect it to my Fatty's (nickname RaRa) battery terminals it doesn't half get hot. I am currently in Medellin, Colombia (for son's wedding and a bit of R&R afterwards, no white powder jokes please) and I would have left it trickle charging good old RaRa if I had the confidence that it would cool down after a few hours. Any comments gratefully received. Cheers, Tony If it ain't broken, fix it till it is. |
4th May 2016 6:10pm |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
I most certainly agree with this bit Pete!
Gets a from me! Dan 2002 Zambezi Silver Men And Motors RR Quote - It's like having wheels fitted to your living room! |
5th May 2016 6:07am |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 |
I use an Accumate charger, and have permanently connected the wires to the battery (I then simply plug the charger in when required, before connecting to the mains). No problems with temperatures on either my FF, or on the D3 that preceded it.
5th May 2016 6:55am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
2008 MY Supercharged
5th May 2016 1:21pm |
robval Member Since: 04 May 2016 Location: derbyshire Posts: 12 |
Hi My sons girlfriend works for a firm that makes cats and DPFs and they recommend 20 mins a week at "motorway speeds" to burn carbon out of the DPF to prevent it clogging up.So this seems to support your theory.
9th May 2016 11:15am |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 |
I have a VW Transporter with the 2.0TDi engine and use it mainly around town for short runs and every so often the DPF warning light comes up and advises to drive between 1800 - 2500 rpm until the light goes out so the above is true, regular "beans given" is certainly the best way.............just have to get used to doing it the RR as I've always been a very light right foot type of driver, looking forward to getting into a new habit then |
9th May 2016 2:10pm |
Pilgrimmick Member Since: 11 Mar 2016 Location: West Coast Posts: 64 |
I use caterpillar engines at work, the 3516 if you are interested, these are a sixteen cylinder twin turbo engines of about 75 litres capacity. (Not sure of the exact capacity, as when you get to engines of this size it is no longer relevant)
9th May 2016 7:04pm |
