Home > Maintenance & Mods (L322) > Check your tailgate straps
To all those who don't know yet or are new , check the straps after winter . I did mine 4 years ago and it's dry here 😦
 2008 MY Supercharged
Post #385160 4th May 2016 7:56am
Update , I did the other side when I fitted the soft close😡 but anyway check them 👍 2008 MY Supercharged
Post #385162 4th May 2016 8:04am
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Hi Axle,
Do you live near the sea, or been driving on the beach?
After only four years something caused it.
Cheers, Jerry THIS WRECKAGE
Post #385182 4th May 2016 11:24am
very common problem.. the water from the rear screen runs down to the strap bolts and rusts them..
one of mine broke whilst my wife and i were standing on the tailgate , luckily my wife just jumped down and i was starting to ... ... - .- -.
Post #385184 4th May 2016 11:49am
Road Stone
So from washing the car too I guess.
Just checked mine, look new.
As you say something to keep an eye on.
Post #385204 4th May 2016 1:38pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi Axle
I have a few days off and can you believe I did this on both cars today.
They weren't as bad as your picture - only a slight rust on the face - however I took off both straps and took apart - placed them in a vice and wire brushed the ends.
Then I ve sprayed Hammerite Black over he metal - left in the sun all afternoon and they are rock hard coated in Hammerite Black - that should stop any rust getting their
Easy job to do and I think it would be well worth the effort.
Note: when you do up the nuts ( both top and bottom ) leave then slightly slack as movement has to take place in order for the strap to fold down.
anyway - good post Alex - well worth mentioning to all FFRR owners Thumbs Up
Post #385255 4th May 2016 8:08pm
p38arover
Australia
Same applies to the P38A. Sad Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #385292 4th May 2016 11:09pm
rar110
I just replaced mine after one broke.
A smear of grease under the rubber cap once a year would help a lot I think. ______________________________
Post #385342 5th May 2016 11:20am
Dogfishdave
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Did both of mine last week.
Just in time I think, they were bad
Post #385346 5th May 2016 11:35am
Was never an issue with the Classics....
 Discovery 4 HSE
Post #385350 5th May 2016 11:55am
pic of my strap on me old td6,
http://www.fullfatrr.com/forum/topic12664....ate+straps ... - .- -.
Post #385352 5th May 2016 11:57am
EmiratesA380
Love your Rangie as your supposed too !
Here's what Ive done - easy to do - just ensure you photograph all the pieces before you take apart to help when you rebuild - NOTE: do not tighten up nuts too tight - they have to have a bit of slack in in order to move when tail gate is closed. ( check when you have finished )
Hope this helps anyone.
Post #385620 6th May 2016 7:36pm
Brian
Good job I read this thread Shocked I just looked at mine and they are in really bad condition so I better order a couple up and get them fitted Thumbs Up
Post #385642 6th May 2016 9:43pm
