Home > Maintenance & Mods (L405) > A spot of DIY...not
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
A spot of DIY...not
The annoying squeal from the front pads under light braking got the better of me.
Whipped the wheels off and set about drifting the retainer pins out...2 hours later they've not moved a mm...seized into the caliper. The car is 3 years old...not good. The pads look to be worn unequally each side of the OSF disc too...4mm on one pad and 7mm on the other, so not sure if that indicates a problem?
Going to set about it again this weekend with a bigger hammer and a pin punch with indent...hopefully that along with some release fluid will do the trick...If not, I've asked Dan for a price for new pins ad I'll cut the Censored out. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #385115 3rd May 2016 6:19pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
How many miles have you done? On three of my L405 the brakes started squeaking under light braking at around 22k miles. All were replaced under warranty.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #385138 3rd May 2016 9:22pm
paulmoran2
Nick..49k right now. Surprised about the warranty cover...not sure if my LR extended woud cover unless its a TIB notified issue? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #385154 4th May 2016 6:19am
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
No wish to teach grandmothers to suck eggs but there aren't little retaining clips holding the pins in place on the blind side of the calliper are there?
Not done this job on a RR (only got mine four days ago) but I know from other vehicles these can be hard to see sometimes and are extremely effective in stopping the pin moving.
Post #385155 4th May 2016 6:37am
Nick Ground
I think there was a bulletin and the parts were superceded for this hence under warranty. But only if customer complained, as per normal JLR.
49k might be pushing it.
55 D3 SE
98 MX5 1.8 RS
Post #385163 4th May 2016 8:09am
362bkr
Not done this job on a RR (only got mine four days ago) (quote)
In that case where are the pics ? Very Happy
Post #385169 4th May 2016 9:16am
Mactech
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Did this job on my 2012 Brembo braked L322 last week.
I found the trick was to use release fluid and allow to soak for 30mins, tap the pins from the back (the wrong way!) to release the holding clips, then use a good quality 5mm parallel punch.
The tap at the back works well as the force is not diffused down the long pin to unlock the internal expanding clips Smile
Used to do pads and discs on Le Mans cars in about 40secs....these took me 40 minutes....a side! Embarassed 2012MY Range Rover 4.4 TDV8 Vogue...now gone!
2007MY Mercedes C200 Estate 'Albert'
1997MY Defender 90 TDI 'Vera'
Post #385177 4th May 2016 10:36am
Macpaul
Ha! Pending a respray by the selling dealer of the side vents/gills!
Had Defenders for a few years over on one of Martin's other forums. Great cars, but now sitting a bit more comfortably... Thumbs Up
Post #385185 4th May 2016 12:03pm
362bkr
Well, looking forward to seeing . Thumbs Up
Post #385201 4th May 2016 1:18pm
Welcome to the club Macpaul - the only prob you got with your car: it is a Diesel and it has the steering wheel on the wrong side Wink All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #385203 4th May 2016 1:35pm
paulmoran2
@Macpaul..couldn't see anything,but now you've mentioned it I'll check again.
New pins are ONLY £40 ( that's for 4 pins mind you)..might see if a warranty change is available
New pads £195....Jeeze GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #385228 4th May 2016 5:02pm
