Home > Wheels & Tyres > Slack nuts ! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Which Nut? Caliber or wheel? There is nothing that can't be fixed with a hammer😜😜
30th Apr 2016 11:24am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Wheel nuts |
30th Apr 2016 11:25am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
It's either:
30th Apr 2016 11:34am |
What sized socket are you using?
30th Apr 2016 11:39am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
The nuts have a stainless cover that fits over the actual nut, you put the socket over these covers, they will have play in them and move a bit, as long as the nuts are done up tight you will be OK.... Pete
30th Apr 2016 1:05pm |
Was going to say what Haylands said also |
30th Apr 2016 1:10pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Haylands is your man , sloppy stainless steel caps . think nothing of it 2008 MY Supercharged
30th Apr 2016 4:49pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
I agree! |
30th Apr 2016 8:00pm |
Well done those that said.......Loose SS Caps you were all quite correct
1st May 2016 9:18am |
Hope you put some grease on those mating surfaces otherwise you will have corroded on wheels the next time you try to take them off.... Pete
1st May 2016 11:45am |
All greased up matey |
1st May 2016 12:12pm |
