Home > Technical (L322) > Oil change problems.
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Hi Folks.
I have an 09 3.6 and I recently took it to a local Indy for an engine oil change, when I went to collect it I was informed that the sump plug has stripped a few threads on removal but went back tight this time but will need attention in the future. Now my question is when I asked them which sump plug as I assumed there was 2 on my engine they told me there is only 1? My worry now is as the car has been there for the last 2 services my oil has not been totally replaced? Can anyone confirm how many sump plugs my car has?
Regards Gary
Post #383828 26th Apr 2016 7:16am
proser
there are 2.
the second one is further back and inline with a crossmember below it. You don't get much out from that one, but it all counts.
Details can be found here - http://www.fullfatrr.com/forum/topic2393.html Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #383839 26th Apr 2016 8:24am
rangie47
Next time you change your oil .
Change your indy 2007 tdv8 se ,stornaway grey
Post #383841 26th Apr 2016 8:25am
Garyfax
Thanks folks. I think I will be changing my Indi.
Post #383844 26th Apr 2016 8:45am
wealy
How can he call himself an indy ???
Question
Post #383895 26th Apr 2016 3:24pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Yes I agree change the indy but he didnt have to say anything did he - perhaps he thought he was doing the right thing?? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #383902 26th Apr 2016 3:49pm
wealy
The sump plugs should be changed on each service. My worry would be the stripped thread? I would get it to a specialist pretty quick.
Post #383905 26th Apr 2016 3:51pm
Garyfax
No he didn't have to say anything however he also told me what a massive job it is to change the sump due to having to remove the driveshafts etc. I was more worried about the fact they didn't know it had 2 drain plugs to be honest as I try to keep up with things. The last 2 oil changes have been done incorrectly now as far as I'm concerned. Very annoying!
Post #383907 26th Apr 2016 4:00pm
holidaychicken
Not the same engine but my sump plug thread is on it's way out so I have a helicoil kit and new bolt on standby for the next time I change my oil which would save the sump removal if done carefully.
Post #383996 26th Apr 2016 9:50pm
Garyfax
Yes I think that will be my plan, what size did you get?
Post #384017 27th Apr 2016 5:29am
ebajema
Try to find out which part is missing threads. If it is the plug, they can be replaced but if it is the oil pan, then a helicoil should do the trick. Get someone who knows how to do a helicoil properly though !!!! MY 2010 5.0 SC Galway green and sand interior!!
Post #384029 27th Apr 2016 7:07am
Garyfax
Yes it's the pan unfortunately.
Post #384055 27th Apr 2016 11:31am
holidaychicken
This is similar to the one i purchased. My engine is the 4.4 V8 petrol M62 BMW engine 2004
http://www.ebay.co.uk/itm/M12-X-1-5-X-16-3...Sw5ZBWMjzt
Post #384117 27th Apr 2016 5:52pm
Garyfax
Thanks mate
Post #384450 29th Apr 2016 12:35pm
holidaychicken
That is likely to be a different size to what you need though
Post #384476 29th Apr 2016 4:47pm
