![]() | Home > Technical (L322) > Many warning signs, all together! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Normally when you get a whole raft of warnings it's low battery voltage related.... had you been driving it far or just around the corner.....which around here can be a few miles |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
Alternatively could well be a split intercooler/turbo hose - they are a well documented failure on the 3.6 TDV8 and tend to cause problems when you accelerate hard - usually accompanied by a decent amount of black smoke. Restart the engine & everything is OK until you accelerate hard agin |
So what are you saying Alistair? the car doesn't have split turbo hose in it vocabulary, so it lists everything that it can think of that isn't the fault |
'Special Operations Off' was the message I got the first time mine went |
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 ![]() ![]() ![]() |
Perce, can you do me a favour. Mine is doing the same thing but the car is with the dealer being fixed at a the moment(3 weeks now) so I can't try it on mine.
Perce Member Since: 30 Jan 2012 Location: Milton Keynes Posts: 163 ![]() ![]() ![]() |
Dave,
Thanks Chris, thanks for that, hope your faults was a one off and don't return.
saucyboar5 Member Since: 08 Sep 2015 Location: Staffordshire Posts: 20 ![]() ![]() ![]() |
Unnecessary quote removed
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Had the same on mine , turned out it was a faulty brake light switch ?? CURRENT : FFRR 2012 4.4 TDV8
