Home > Technical (L322) > Many warning signs, all together! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Normally when you get a whole raft of warnings it's low battery voltage related.... had you been driving it far or just around the corner.....which around here can be a few miles It might be an idea to check the voltage before starting... should be around 12.5 volts, and with the engine running... should be at least 14 volts preferably 14.5 v Yesterday I couldn't spell Engineer... Today I are one!
27th Mar 2016 10:02pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
Alternatively could well be a split intercooler/turbo hose - they are a well documented failure on the 3.6 TDV8 and tend to cause problems when you accelerate hard - usually accompanied by a decent amount of black smoke. Restart the engine & everything is OK until you accelerate hard agin
28th Mar 2016 7:19am |
So what are you saying Alistair? the car doesn't have split turbo hose in it vocabulary, so it lists everything that it can think of that isn't the fault There are times when I wonder if the Screen of Doom and the Death Bong haven't got built in instant Dealer profit Yesterday I couldn't spell Engineer... Today I are one!
28th Mar 2016 8:44am |
'Special Operations Off' was the message I got the first time mine went
28th Mar 2016 8:59am |
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 |
Perce, can you do me a favour. Mine is doing the same thing but the car is with the dealer being fixed at a the moment(3 weeks now) so I can't try it on mine.
28th Mar 2016 10:11am |
Perce Member Since: 30 Jan 2012 Location: Milton Keynes Posts: 163 |
Dave,
28th Mar 2016 12:00pm |
Thanks Chris, thanks for that, hope your faults was a one off and don't return.
28th Mar 2016 6:25pm |
saucyboar5 Member Since: 08 Sep 2015 Location: Staffordshire Posts: 20 |
Unnecessary quote removed
25th Apr 2016 10:19pm |
So that's one down to the super quality of our diesel... that doesn't say it's Bio, even though some of it is
25th Apr 2016 10:51pm |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Had the same on mine , turned out it was a faulty brake light switch ?? CURRENT : FFRR 2012 4.4 TDV8
26th Apr 2016 6:33pm |
