Home > Technical (L322) > TDV8 Possible Injector Failure |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 157 |
Sadly now seen a number of failed EGR valves on 3.6’s and one on a 4.4 where the end of the valve breaks of and the bits go down through the valves and the pistons then stamp them back against the cylinder head, end result in these failures is a scrap head and piston and potentially a scrap block.
19th Apr 2016 7:50pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I think I might buy a set of emulators. ______________________________
19th Apr 2016 9:48pm |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
She currently in the garage having the head removed to get at the EGR. Well at least that what I think is happening. It's very strange because its running apart from misfire. I see on another thread you are in contact with Land Rover regarding engine failure, I doubt this will be of any help to me. I'm trying to source a replacement engine, but they are costly. If an EGR valve is damaged, what do you suggest I do then? Would like to get her back up and running. Think I'm going to part with her then, sadly whilst much nicer than a LandCruiser. No where near as reliable. If only Land Rovers were as reliable as Toyotas. |
20th Apr 2016 12:33pm |
The EGR valve broke and went into the engine. That is where we are currently at.
20th Apr 2016 4:54pm |
Sorry to hear that, from here your options are limited by lack of supply of parts from LR.
20th Apr 2016 5:24pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
As above, sorry to hear about the damage.
20th Apr 2016 6:35pm |
I'm very sorry to hear it is worse than we hoped. I'd say get a full damage assessment first to see whether it is an engine replacement or a fix of the current engine.
21st Apr 2016 2:02am |
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 |
Yes terrible news and very sorry to see it panning out this way.
22nd Apr 2016 9:04am |
Im not sure if the latest Defender is any better. It makes me want a 5.0 V8. ______________________________
22nd Apr 2016 9:51am |
And you'd never want a diesel again rar110 MY 2010 5.0 SC Galway green and sand interior!!
22nd Apr 2016 1:08pm |
Cheers everyone for your comments and feedback. It is indeed sad that the situation has come to this. However, no one is hurt and I will get her sorted. Alas, each time something like this happens it does damage my passion for the Land Rover brand.
22nd Apr 2016 1:11pm |
Landcruisers aren't all they're cracked up to be. Our Landcruiser in Nigeria was far less reliable (and comfortable) than my 4.2 SC and that SC wasn't the most reliable either. My 5.0 SC has been faultless to date at 6 years of age and 90k miles.
25th Apr 2016 1:49am |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
11th May 2016 11:51am |
