![]() | Home > In Car Electronics (L322) > Rear Passenger side electric window not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
re check the connections, it has to be the problem.. ... - .- -.
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
hi stan, there is only one connector going into the window switch, and its been reseated several times so i dont think thats an issue, surely it would still work from the Drivers side main switch panel also? |
the WM says that window operation doesnt work if the front door is open..not sure what that means but shut all doors and try the windows...
Thanks Stan, i shut both front doors and tried, and i can now hear it Clicking from the BCM under the seat but the window still doesn't work, all the others work fine.
i still think its the connection, maybe a bent pin ? or maybe a broken wire ? ... - .- -.
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 ![]() ![]() ![]() |
I had a similar problem a couple of weeks ago. Both rear windows wouldn't work from the drivers door switches or the rear switches. I could hear the BCM clicking along with the odd dull thud from inside the doors. Eventually, after much fiddling with all the switches they both kicked into life and now seem fine. I can only put it down to lack of use and/or dirty switch contacts. |
i have now got a code from BCM, rear window lift fuse faulty
