Home > Technical (L322) > Changed Puncture and now fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8189 |
Constantly filling up the system, usually indicates a small leak in a bag, you could have tipped it over the edge with jacking it up, a part of the bag that never gets folded, will be folded, and has probably developed a leak... out with the soapy water in a spray bottle, then get suspension all the way up to off road and squirt away.... Pete
18th Apr 2016 8:51pm |
welderman Member Since: 02 Oct 2015 Location: Lancashire Posts: 14 |
18th Apr 2016 9:10pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
Conceptually the bags aren't too difficult to replace. However...
18th Apr 2016 9:30pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
umm When you say "Blowout" was that it went flat and still looks like a tyre, or was it totally disintegrated and looks like a few bits of rubber stuck on a rim....... cos if we is talking, there is nothing left that resembles the tyre there is a chance that the airbag may have been punctured by the bits of tyre falling off
18th Apr 2016 10:12pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
The OP has a 4.4TDV8 so the front legs are twice the price of yours from island 4x4 |
18th Apr 2016 10:54pm |
Reckon this should save a few quid
19th Apr 2016 12:01am |
Electronic adaptive dampers.... Pete
19th Apr 2016 12:10am |
I stand corrected.
19th Apr 2016 5:47am |
And thats the much cheaper after market Island 4x4 route
19th Apr 2016 6:40am |
The rear drivers tyre went pop has a hole big enough to put your finger in, lucky for me I was just entering a 50mph zone on the motorway. The rest of the tyre was fine, the side wall was too with it running flat.
19th Apr 2016 7:25am |
No particular reason apart from it's what went on mine and I was guessing that if a tyre went it was more likely to be a front as that would hit something first. Ed |
19th Apr 2016 7:31am |
Right so the bad news is you are still feeling a little deflated
19th Apr 2016 3:32pm |
Just popped down to Landranger in Atherton, only 25 min from me, Martin deleted the fault code and hopefully that sorted it. Fingers crossed.
20th Apr 2016 12:14pm |
