Home > Maintenance & Mods (L322) > Tailgate and console struts
rar110
I replaced the upper tailgate struts last night using genuine parts. It's improved lift. However, I expected the new struts to lift the upper tailgate as soon as the open switch was triggered. It currently needs to be lifted the first 20-30cm then it lifts. Is that normal or have I scored old stock from JLR that's degassed sitting on the shelf?
As an aside it was a very easy job.
I also replaced the bottom lid strut on the centre console, which took a lot longer. I didn't think there was another strut for the upper lid. Are they the same part number?
The price of the above struts from the Australian dealer wasn't too bad. It was a cheaper on eBay but not a heap cheaper.
Thanks ______________________________
Post #382339 15th Apr 2016 8:48pm
your 'lift' sounds about right.. Thumbs Up ... - .- -.
Post #382343 15th Apr 2016 8:54pm
rar110
Thanks Stan. ______________________________
Post #382363 15th Apr 2016 10:30pm
miggit
I think that L/R would get a few complaints if the tailgate opened it's self.... especially if your stood next to it Shocked
I replaced the struts on my Merc ML, they are after market.... think that they might have over done the lift.. if you aren't quick enough it gets you in the plums Shocked Big Cry Censored Need less to say I'm very good at the quick step now Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #382366 15th Apr 2016 10:51pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I have used struts from the ebay seller gasstrutguys for several cars and will use them again. Always less than $30 shipped a pair. (15 Pounds) I did my L322 and can report that after pressing the release on the remote the tailgate lifts a few mm to clear the catch and then with minimum effort from me to start it moving up after about 150mm the struts take over and the tailgate lifts itself till fully open. A bargain. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #382382 16th Apr 2016 2:31am
rar110
Thanks. They are a lot cheaper. Next time. ______________________________
Post #382383 16th Apr 2016 5:06am
p38arover
Australia
I don't know if it is possible to fit longer struts - I keep bashing my head on the tailgate. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #382385 16th Apr 2016 5:47am
rar110
Ron you must be quite tall. I've adjusted the normal height of my RRV with the IID tool so it's 20mm lower. There is 185cm of clearance under my open upper tailgate. The struts at full extension are 52cm. ______________________________
Post #382388 16th Apr 2016 6:20am
wayneg
There must be something in the air at the mo, just lifted the bonnet to refill the screen washer reservoir and the airsprings were no longer up to the task of holding it up Evil or Very Mad Quick look on Ebay and gasstrutguys has a pair for A$27.50 shipped. Smile
[/url]http://www.ebay.com.au/itm/BONNET-STRUTS-suit-RANGE-ROVER-L322-MODEL-inc-VOGUE-02-to-12-OEM-QUALITY-PAIR-/351693987006?fits=Model%3ARange+Rover&hash=item51e2985cbe:g:K68AAOSwZ8ZW1jWU[url] 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #382400 16th Apr 2016 7:42am
miggit
Do you leave the car in low mode / height.... cos I'm in danger of bashing me brains in when the car's in low Shocked Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #382442 16th Apr 2016 11:50am
p38arover
Australia
I don't normally leave the car in access mode but I have been lately whilst I'm fitting my camping drawers and fridge.
I must remember to measure the extended strut length. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #382820 19th Apr 2016 7:53am
wayneg
Fitted my new A$27 pair of bonnet struts today, 5 min fit and all good. The old ones were well past it 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #382919 20th Apr 2016 4:16am
