Home > Technical (L322) > URGENT- Lost ALL ELEC POWER. Solved!!
Dolphinboy
Was driving fine then pulled in and put her into park. Went to switch engine off and engine stuttered then everything went off. Removed key but will not turn on now. No power to anything but dvrs side repeater pulsing weakly. Have checked btty connections - all good
Help pls. Fuse number to check? Things to look at? Reset procedure?
Thx
DB
Post #382296 15th Apr 2016 7:09pm
check battery , alternator...any belts come off? ... - .- -.
Post #382297 15th Apr 2016 7:14pm
Dolphinboy
Hi stan. Can't check batty power as by side of road but all connections good. Belts all ok and alt good just on inspection.
Post #382298 15th Apr 2016 7:16pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
It does sound like a total battery fail.
Post #382299 15th Apr 2016 7:23pm
could be the 5amp BCU fuse in the main fusebox [under the CD multiplayer] ... - .- -.
Post #382301 15th Apr 2016 7:24pm
Dolphinboy
Boxy fuse number??
Post #382302 15th Apr 2016 7:27pm
Dolphinboy
F ing auto text!
BCU fuse no. Pls?
Post #382304 15th Apr 2016 7:28pm
Do the headlights / sidelights work?
Post #382305 15th Apr 2016 7:29pm
brian1951
Try no 41
Post #382308 15th Apr 2016 7:41pm
johnboyairey
Have you any jump leads?
Maybe leave bonnet up, stand by road holding them, and maybe a sexy chick, will pull over and offer you jump!
If you have no headlights, you surely have no power. Maybe you battery let go, but car was running under power of constant alternator current. If you can jump it, you might get home. On sidelights etc.
Post #382310 15th Apr 2016 7:47pm
johnboyairey
If you can get hold of a battery, (any type with terminals suited) and a 10mm spanner, (in tool wallet) you have the best chance of getting home.
What about, if you get the wing mounted repeater out, or a tail bulb spare in the glovebox....and find something like wire, to extend one of the terminals, and try it over the battery terminals, is it bright? Or mediocre?
Post #382314 15th Apr 2016 8:05pm
No lights on the dash on the lead up to this ?
Sounds like the alternator has packed up, so you've been running on battery and have now killed that.
I assume you don't have AA/RAC or similar ?
Post #382317 15th Apr 2016 8:24pm
johnboyairey
I found out, that being a Barclays customer, I have some form of breakdown cover. Ive never used it....as we have green flag anyway, but might get you out of a tight spot.
Post #382319 15th Apr 2016 8:32pm
+1 for a goosed alternator and run the battery flat. There is nothing that can't be fixed with a hammer😜😜
Post #382323 15th Apr 2016 8:50pm
Dolphinboy
Thanks for all your help chaps. Absolutely no power still. No lights or anything Anywhere except for that repeater! - have AA but had to leave the old girl to get back to my younger girl who was having a bad day with the onboard dolphin boy junior.
Suspect a short somewhere but will go back later tonight and see what I can resuss.
Will update when I can.
DB
Post #382336 15th Apr 2016 9:44pm
