![]() | Home > Technical (L322) > URGENT- Lost ALL ELEC POWER. Solved!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35654 ![]() ![]() |
check battery , alternator...any belts come off? ... - .- -.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Hi stan. Can't check batty power as by side of road but all connections good. Belts all ok and alt good just on inspection. |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
It does sound like a total battery fail. |
could be the 5amp BCU fuse in the main fusebox [under the CD multiplayer] ... - .- -.
Boxy fuse number?? |
F ing auto text!
Do the headlights / sidelights work? |
Try no 41 |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Have you any jump leads?
If you can get hold of a battery, (any type with terminals suited) and a 10mm spanner, (in tool wallet) you have the best chance of getting home.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
No lights on the dash on the lead up to this ?
I found out, that being a Barclays customer, I have some form of breakdown cover. Ive never used it....as we have green flag anyway, but might get you out of a tight spot. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
+1 for a goosed alternator and run the battery flat. There is nothing that can't be fixed with a hammer😜😜
Thanks for all your help chaps. Absolutely no power still. No lights or anything Anywhere except for that repeater! - have AA but had to leave the old girl to get back to my younger girl who was having a bad day with the onboard dolphin boy junior.
