![]() | Home > In Car Electronics (L322) > ULF -> Phone Compatability |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
My iPhone 5 worked fine with the version 6 ULF I fitted to the TD6 2011 Range Rover Vogue SE 4.4 TDV8
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
My HTC One M9 paired perfectly first time with the same module, wot I bought off mjdronfield |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
Thanks both,
You can pair up to 3 I think. It will then connect to the last one to come into range each time the cars started..... So get in the car last !
Well my ULF showed up on Saturday, so got everything installed on Sunday afternoon. I used a couple of the unused cradle wires to put a pairing button underneath the centre cubby rubber base. So just pop it out and I can pair from the front |
