![]() | Home > Technical (L322) > TDV8 Possible Injector Failure |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
Anyone? |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
Sounds likely to be an injector issue or potentially a EGR value with the end dropped off, don't ask how I know that one...
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I cant recall reading about a tdv8 injector failure. Try the cheap easy solutions first like a good injector cleaner.
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
interesting as mine has on occasion showed these sort of symptoms.
Have you checked the turbo hoses, maybe a small crack developing that is causing issues. Check connectors/wiring etc.
No more info yet for you guys. She is currently with the mechanic so I'm hoping to know more tomorrow. Really hoping it is the case of a failed injector, as I can get it refurbished or replaced quickly and easily. Turbos, EGRs etc etc is much more expensive.
If it is just one cylinder not working (properly) than it is unlikely to be turbo related and much more likely to be the fuel supply to that cylinder (well in a diesel engine of course). It could still be wiring/connector as well though.
I agree. Could be a loom or connector fault. ______________________________
interestingly, mine hasn't logged anything in IID tool although has done it three/four times now 2007 Vogue TDV8 with 255/55/20's fitted |
Porridge Member Since: 31 Mar 2011 Location: Dublin Posts: 51 ![]() ![]() ![]() |
I still get that slight lumpiness.
Number 2 isn't pulsing. But the mechanic said he blanked this injector off and it didn't make much difference to the engine tone? He seems to think more injectors could be faulty. He is going to be working on it tomorrow morning. Any other tips? He seems convinced that it's only an injector problem. However, I'm not so sure.
DSCOOPS Member Since: 15 Jul 2015 Location: Staffs Posts: 26 ![]() ![]() ![]() |
Any update? |
Still waiting. The mechanic isn't the rushing type! But no harm, hopefully will have full details tomorrow. First second I know, I will report back here.
Injectors are working anyways.
