Home > Maintenance & Mods (L322) > 2010/12 Taillights Issues |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 242 |
Great. So now after a fair bit of reading at other boards it looks like voltage needs to be reduced from 12v to 6v as 2010+ led taillights require 5v to work. That is why these are so bright now.
10th Apr 2016 1:20am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Could you not use one of those HGV / Truck 24 to 12 droppers and then only give it 12 on the 24 side? might work... then you could use some 12 V relays to switch the lights from your 6 v supply
10th Apr 2016 7:27am |
Yup, I was looking at these 12 to 6 v converters. The thing is these have to be added to every line and from what I read on other forum turn signals stop working with these added. All the rest is correctly dimmed but blinkers somehow dissapear totally. 07 3.6 TDV8 Vogue
10th Apr 2016 10:22am |
Have you tried straightforward resistors on each line cutting the 12 to 6 Volts ? Just find a decent electric component shop and experiment a bit with them or find a good electronics specialist to sort it out for you MY 2010 5.0 SC Galway green and sand interior!!
10th Apr 2016 10:44am |
Today I just ordered a set of magic boxes from super tweaks for GBP 225.
10th Apr 2016 3:05pm |
But I start to like the look, even on a dirty Buckingham Blue car:
10th Apr 2016 4:21pm |
betonklinker Member Since: 19 Nov 2015 Location: Amsterdam / Netherlands Posts: 68 |
I use Google translate, Sorry for my bad English...
11th Apr 2016 5:03pm |
Just a quick note that Supertweaks is not a good company to order from.
23rd Apr 2016 5:16pm |
AzizRR Member Since: 08 Feb 2016 Location: Muharraq Posts: 54 |
I ordered overfinch rear spoiler and it arrived a bit late but had no issue with them.
24th Apr 2016 10:16pm |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 |
Ordered plenty of times from Supertweaks including my modules front and rear and not had any problems. Plenty of others have ordered from them as well. Recommend from me. |
25th Apr 2016 5:05pm |
