![]() | Home > Maintenance & Mods (L322) > 2010/12 Taillights Issues |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 252 ![]() ![]() ![]() |
Great. So now after a fair bit of reading at other boards it looks like voltage needs to be reduced from 12v to 6v as 2010+ led taillights require 5v to work. That is why these are so bright now.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Could you not use one of those HGV / Truck 24 to 12 droppers and then only give it 12 on the 24 side? might work... then you could use some 12 V relays to switch the lights from your 6 v supply |
Yup, I was looking at these 12 to 6 v converters. The thing is these have to be added to every line and from what I read on other forum turn signals stop working with these added. All the rest is correctly dimmed but blinkers somehow dissapear totally. 12 4.4 TDV8 Vogue
Have you tried straightforward resistors on each line cutting the 12 to 6 Volts ? Just find a decent electric component shop and experiment a bit with them or find a good electronics specialist to sort it out for you |
Today I just ordered a set of magic boxes from super tweaks for GBP 225.
But I start to like the look, even on a dirty Buckingham Blue car:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Nara Bronze / Arabica / Ivory / Piano 07 3.6 TDV8 Vogue Buckingham Blue / Sand / Piano |
betonklinker Member Since: 19 Nov 2015 Location: Amsterdam / Netherlands Posts: 68 ![]() ![]() ![]() |
Just a quick note that Supertweaks is not a good company to order from.
AzizRR Member Since: 08 Feb 2016 Location: Muharraq Posts: 54 ![]() ![]() |
I ordered overfinch rear spoiler and it arrived a bit late but had no issue with them.
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Ordered plenty of times from Supertweaks including my modules front and rear and not had any problems. Plenty of others have ordered from them as well. Recommend from me. |
