![]() | Home > Maintenance & Mods (L322) > TD6 - to blank off EGR or remove and clean? |
boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162 ![]() ![]() ![]() |
tbh cant really help but hoping a guru or 2 will come along I'm not sure if mine has been deleted or not but has been re mapped by previous owner and wow it makes a difference for sure 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
Remove it. It's the work of Satan.
If you do take it off and I recommend you do, clean it up and put in a safe place for possible future re-fitting just in case it becomes an MOT inspection item. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
I would have thought if you've had it remapped, it should have been blanked.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35627 ![]() ![]() |
blank it... |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
blank it... and remap it |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I ditched mine last year and it's been good ever since |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1457 ![]() ![]() |
I don't have one, but if I did.....
Thankfully that is one part of the engine that Land Rover got right, they declined the swirl flaps as they didn't want to as unreliable as a BMW...... and then they beat them on experience |
The gearbox isn't that bad..... just don't tow in normal range between 30 and 50 for long times... if you have a tin tent and your sitting at 55+ then there are no worries |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
100% remove it, Not long after getting my TD6 I did the delete, went to the trouble of removing the inlet manifold and cleaning all the gunk out, Vortex breather, K&N type filter and tune chip all at the same time. Difference was chalk and cheese. 2007 TDV8 VSE
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 763 ![]() ![]() ![]() |
Resounding vote then guys, cheers (was expecting as least 1 'perfectionist' who said leave it as RR wanted)
Nice and easy job just to fit the blanking piece. No need to clean anything unless you want to take off the inlet manifold and clean out all the gunk. That is a disgusting task but again easy, just more time consuming 2007 TDV8 VSE
