![]() | Home > Maintenance & Mods (L322) > Here we go..Update |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
New caliper. If you repair it you are only delaying the inevitable.
I'd suggest to get a fully refurbished on from Dan, they're fairly cheap and the replacement is relatively painless. Unless you have a refurbishment place nearby, it is probably the quickest and easiest way.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8002 ![]() ![]() ![]() |
Two refurb callipers from Dan is the way to go - that's what I did when one of mine started sticking.
I agree with Alistair, it is like no.2 is to go soon so considering the relatively low cost of the calipers and the little extra work when the one is being replaced, it makes good sense. My 2p worth |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
needs to be done today though, car needed for next couple of days and no spare vehicle.
In that case you could try to get the sticking one workable again if you have a good local indy that can do that type of work while waiting for the new calipers to arrive............ If you keep driving the bearings and disc will heat up and can get b*ggered because of that. MY 2010 5.0 SC Galway green and sand interior!!
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
When I got mine 2007 done I replaced caliper and both pads and discs, had 'em done by an Indy in Leyland (K Motors), did the same with the SC recently - much more expensive |
If it really needs to be done today, then you're paying whatever they tell you it will cost..... Are you doing it yourself ? Generally you'd be lucky to find a garage that can get you in that quickly. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
I think ECP do recon units... Not used them but pretty sure I’ve seen them in their bumf... |
They do Pagid at ECP. I can fit it at the garage next door who will open up his snap on chest to me !! Cant get it on his ramp though because the ' cheap' replacement engine he bought off eBay for an old shogun he's doing up was started on monday following two days of fitting..... and sounds like 3 monkeys banging spanners on the side of a biscuit tin !! |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
If you want a 'today' fix, then:
Got it on the ramp and wheel off. Disc and pads in reasonable condition. Dismantled calliper and checked piston which showed no signs of corrosion and which pressed in and out quite easily. However, hub very stiff so backed off handbrake shoes which freed it up a bit and so that it matched stiffness of other side.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
make sure that you clean the caliber carrier where the pads sit, not just the metal clip.
Great minds think a like !! Rubbed down the corrosion off the carrier like you said as this can force the clips out of position and add to the ill fitting of the pads. Generally get trade prices off ECP and Genral Traffic so I'll be checking out calliper prices.Must admit, its looking like the EPB is causing the problem. Backed the shoes off to just biting but if you go to far, the bill oddie thing registers a fault because it thinks the parking brake isn't working. |
