Home > Technical (L322) > occasional warm start failure
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
on 3 occasions i've experienced my 2004 diesel turning over but not firing.
each time i have been on a run of of at least 5 miles.
if i leave it for 5 or 10 minutes it fires into life, i've changed the fuel filter agiain even though it had one 3000 miles ago.
has anyone had a similar problem?
cheers
steve
Post #379480 26th Mar 2016 11:35am
miggit
I would suggest that you have it plugged in to see if there are any faults.... I had a similar problem, but when mine didn't want to start, it would after a while, cough in to life.... turned out to be 2 injectors... but I had to leave mine for hours to get anything near normal starting, and when it all finally gave up, I had the worse misfire ever.... felt like clutch judder, only I don't have a clutch Shocked
If your car is not showing any faults then I'd be looking at the injectors.... but from what you have described, I'd be surprised if there wasn't a gremlin in the works and the ECU has recorded the fault Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #379489 26th Mar 2016 12:35pm
cleughy
had a marginal loss of power, followed by a total loss last week, needed a new fuel pump.
Post #382974 20th Apr 2016 2:24pm
miggit
That would do it, hope it's all sorted now Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #382999 20th Apr 2016 7:47pm
